1999 Nissan Altima oil pump
1999 NISSAN ALTIMA
JUNODALE
Engine Mechanical problem
1999 Nissan Altima 6 cyl Two Wheel Drive Automatic
how to change a oil pump on a 2.4 litre engine
Nov 11, 2008 at 6:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Drain the engine oil
Remove or disconnect the following:
Negative battery cable
Engine front cover
Oil pump cover and pump
INSTALLATION:
Install or connect the following:
Oil pump
Oil pump cover and torque the long bolt to 15 ft. lbs. (20 Nm) and shorter bolt to 69 inch lbs. (8 Nm)
Front cover
Fill the engine with clean oil.
Start the vehicle, check for leaks and repair if necessary.
Nov 11, 2008 at 7:02 AM
