I HAVE A 1999 ALTIMA WITH A LEAK ATHE HEAD GASKET SEAL. IN THE ARE JUST BEHIND THE A/C UNIT, ON THAT CORNER. NO COOLENT IS BEING USED UP, THE PERFORMANCE IS THE SAME AS BEFORE. i HAVE HAD THSI LEAK FOR 8 MONTHS NOW. iT HAS JUST GOTTEN QUITE LARGER THOUGH. mY QUESTION IS, IS IT JUST THE HEAD GASKET SEAL THAT NEEDS TO BE REPLACED, AND WILL THIS FIX THE PROBLEM?
THANK YOU
THANK YOU
Nov 6, 2008 at 1:12 PM
