1999 Nissan Altima ignition switch
1999 NISSAN ALTIMA
12,000 MILES • 4 CYL • FWD • AUTOMATIC
BUDUKER
FRONT WHEELS ARE LOCKED TO THE LEFT.IGNITION SWITCH WILL NOT TURN TO START SEEMS LIKE IT IS THE SWITCH.STEERING WHEEL WILL NOT UNLOCK.
Jul 2, 2008 at 1:11 PM
BMRFIXIT
  • 19,053 POSTS
Rock the steering wheel left and right as u trying to turn the ignition key
Jul 6, 2008 at 2:28 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
The lock cylinder might be jammed. There should be a retaining pin underneath the steering column (small hole). Insert an ice pick or very small screwdriver in this hole. Insert the ignition key and turn ignition to on position and then press in on the screwdriver. Twist the lock and pull away from the steering column.
Jul 6, 2008 at 2:47 PM
