1999 Nissan Altima cooling fans
120,000 MILES • 4 CYL • FWD • AUTOMATIC
KLDLD
the 2 cooling fans do not come on. i checked the fuses/breakers. removed the wiring harnesses and the fans work wiring them direct to the battery. please advise!
checked relays-ok. is there some way to check the coolant sensor without removing it? thanks for the help!
Mar 29, 2010 at 1:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty cooling fan relay and check engine coolant temp. sensor.
Mar 29, 2010 at 3:18 PM
