1999 Nissan Altima Battery light and brake light are blinki
15,200 MILES • 4 CYL • 4WD • AUTOMATIC
ANGIE_MITCH_99
My brake light and battery light is blinking off and on. I just replaced my alternator and battery, and went to auto zone for a diagnosis test, they said everything was ok. So im not sure what the problem is?
Oct 28, 2010 at 12:48 AM
  • 75,988 POSTS
You still have a charging system problem-check fuse no.12 10amp in the fuse block and no.38 10amp and fuse no.E 100amp in the fuse/fusible link box. If all okay double check wiring to and from the alternator
Oct 28, 2010 at 1:47 AM
