1999 Nissan Altima alternater
GEORGEGORE
1999 Nissan Altima 4 cyl Four Wheel Drive Automatic
how would I replace an alternater?
Jan 10, 2010 at 3:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Drain the cooling system below the upper radiator hose level.
Remove or disconnect the following:
Negative battery cable
Upper radiator hose
Alternator electrical harness, harness stay and the harness-to-A/C compressor
Throttle cable
Loosen the adjusting bolt
Accessory drive belt
Alternator mounting bolts
Alternator from the engine
To install:
Install or connect the following:
Alternator and torque the bolts to 11-15 ft. lbs. (16-20 Nm)
Harness-to-A/C compressor, harness stay and the alternator electrical harness
Throttle cable
Drive belt. Properly tension the belt
Upper radiator hose
Top off the cooling system.
Start the vehicle, check for leaks and repair if necessary.
Jan 15, 2010 at 7:50 AM
