1998 Nissan Altima SQUEAL WHEN NOT MOVING ENGINE ON
PMARKLIN
Noises problem
1998 Nissan Altima 6 cyl Two Wheel Drive Automatic
Noticed only at the drivethru a loud, getting louder squeal. It used to go away if I put it from drive into nuetral or park, but not now. As I sit with engine running the car squeals until we drive away.
Dec 10, 2008 at 11:29 PM
  • 75,988 POSTS
You need to check your drive belts tension-if okay could be a bearing problem on the driven components-
Dec 11, 2008 at 12:16 AM
