1998 Nissan Altima My car takes a while to accelerate, What
JCAESAR228
1998 Nissan Altima All Wheel Drive Automatic 65000 miles
As im on the highway I have to press the gas REAL hard for my car to move faster. Can you tell me what could be wrong and what i may need to fix.
Feb 16, 2010 at 11:04 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 16, 2010 at 11:06 AM
