1998 Nissan Altima Engine Running Cool
1998 NISSAN ALTIMA
160,000 MILES • 4 CYL • FWD • AUTOMATIC
MYRSCHI
Even after 1/2 hour of slow in town driving, the temperature gauge only shows just slightly above the Cold mark and the heater blows luke warm air. Thermostat brand new, water pump okay, no coolant leaks and coolant level is okay.
Jan 1, 2010 at 7:41 AM
DOCFIXIT
  • 18,828 POSTS
Are cooling fans running all the time?
Jan 1, 2010 at 7:50 AM
MYRSCHI
No, not at all. Generally once outside temps drop below the teens the fans don't run at all. But they do run a lot when temps are 40 degrees and above. Nevertheless, the car has never overheated or even come close.
Jan 1, 2010 at 8:48 AM
DOCFIXIT
  • 18,828 POSTS
Was air relief plug opened when filling after thermostat. If not sure open run till op. temp. add coolat till all air is expelled.
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_303.jpg
Jan 2, 2010 at 3:54 AM
MYRSCHI
I'll give it a try....thanks.
Jan 2, 2010 at 3:42 PM
