My air conditioning just blows hot air when I turn it on. freeon has already been added and it still does not work. How do I fix it. No leaks
Jul 7, 2008 at 8:17 AM
✓Experienced Mechanic
Hi there,
Get the system pressures tested first, your A/C tech will be able to tell you if there is an internal problem with the system, you may have a high /low pressure switch issue.
