large amount of gas out the tailpipe. When I put my hand next to the tailpipe it gets soaked with gas in a couple of seconds. The smell from all that gas is very bad. I just had the valve cover gasket and the exhaust manifold gasket changed. I suspect it might
have something to do with the computer? The two gaskets were changed because after going on a long ride, 3 hours each way, the
car was running rough and white smoke was coming out the tailpipe. It seemed that the valve cover gasket was leaking onto the intake manifold. The gasket on the exhaust manifold was bad and the oil was getting in and burning out the tailpipe, causing the white smoke.
SPONSORED LINKS
Monday, May 4th, 2009 AT 10:57 AM
