1997 Nissan Altima Timing Or Bad Gas
SBC30093
  • 1997 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • MANUAL
  • 164,329 MILES
I was driving my car after filling up with regular gas and I accidentally shifted from 1st to 4th the car shut off and then ran with a rough idle and sometimes shutting off. Mechanic says it might be bad gas and it wouldnt run if timing was off. Checked gas and gas was yellow in color and smelled very weak. Could timing belt have jumped a couple of teeth or is gas probably bad?
Sunday, June 1st, 2008 AT 12:34 AM
  • 31,937 POSTS
Hi there,
I would be investigating the fuel issue first. & If you do have contaminated fuel when it is drained & flushed don't forget the filter as well, also add some fuel system cleaner.
Mark (mhpautos)
Sunday, June 1st, 2008 AT 4:09 AM
