HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Engine
Symptoms
Not Cranking Over
1997 Nissan Altima Not turning over
AMIRPAJOUYAN
MEMBER
1997 NISSAN ALTIMA
4 CYL
2WD
AUTOMATIC
125,000 MILES
There is no spark in the plug wire, thus the car is not turning over when starting it.
what possibilties could be causing that?
Sunday, February 3rd, 2008 AT 7:16 PM
BLACKOP555
MECHANIC
Chances are its a bad coil/pack or even a bad ignition module.
Sunday, February 3rd, 2008 AT 7:54 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
97 Altima Key Goes In With Ease But Only Turns Over 1/...
I Can Put The Key In And Turn It But It Only Starts To Turn Over When Let's Perfectly Half Way Out. What Should I Replace? Thanks In Advance...
Asked by
Netpacq
1 ANSWER
1997
NISSAN ALTIMA
VIDEO
Car Not Cranking? Try This | EASY
Instructional repair video
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
1997 Nissan Altima
Well The Car Cranks. But It Wont Turn Over. What Could The Problem Be?
Asked by
SPOONER03
1997
NISSAN ALTIMA
1997 Nissan Altima Not Cranking
The Lights On My 97 Altima Come On, But The Engine Does Not Crank When I Turn The Key. Is The Problem The Starter? The Car Was Fine When...
Asked by
JJNYC
1 ANSWER
1997
NISSAN ALTIMA
1999 Nissan Altima Car Dies Won't Turn Over For 20-30...
My Car Started Normally, Put It In Gear And Moved A Short Distance When The Engine Died, All The Lights Come On. When I Tried To Start...
Asked by
jbridgez
1999
NISSAN ALTIMA
1999 Nissan Altima Car Cranks Over But Wont Start.
I Have A 1998 Altima And A 1999 Altima. The 98' Was Wrecked But Ran Good. The 99' Has A Good Body But Has A Rod Knocking. Both Cars Ran Just...
Asked by
jasonbennett
1999
NISSAN ALTIMA
VIEW MORE
Starter Motor Replacement
Battery Replacement Ford
