HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Engine
Symptoms
Not Cranking Over
SPONSORED LINKS
1997 Nissan Altima
SPOONER03
MEMBER
1997 NISSAN ALTIMA
4 CYL
AWD
AUTOMATIC
278,000 MILES
Well the car cranks. But it wont turn over. What could the problem be?
Tuesday, March 9th, 2010 AT 8:32 PM
LEGITIMATE007
MECHANIC
What you have to do first is verify if you have fuel and spark. I'll send something to show you how to do that if you dont know.
SPONSORED LINKS
Tuesday, March 9th, 2010 AT 8:48 PM
LEGITIMATE007
MECHANIC
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Tuesday, March 9th, 2010 AT 8:49 PM
LEGITIMATE007
MECHANIC
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Tuesday, March 9th, 2010 AT 8:50 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
97 Altima Key Goes In With Ease But Only Turns Over 1/...
I Can Put The Key In And Turn It But It Only Starts To Turn Over When Let's Perfectly Half Way Out. What Should I Replace? Thanks In Advance...
Asked by
Netpacq
1 ANSWER
1997
NISSAN ALTIMA
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
1997 Nissan Altima Not Cranking
The Lights On My 97 Altima Come On, But The Engine Does Not Crank When I Turn The Key. Is The Problem The Starter? The Car Was Fine When...
Asked by
JJNYC
1 ANSWER
1997
NISSAN ALTIMA
1999 Nissan Altima Car Dies Won't Turn Over For 20-30...
My Car Started Normally, Put It In Gear And Moved A Short Distance When The Engine Died, All The Lights Come On. When I Tried To Start...
Asked by
jbridgez
1999
NISSAN ALTIMA
1999 Nissan Altima Car Cranks Over But Wont Start.
I Have A 1998 Altima And A 1999 Altima. The 98' Was Wrecked But Ran Good. The 99' Has A Good Body But Has A Rod Knocking. Both Cars Ran Just...
Asked by
jasonbennett
1999
NISSAN ALTIMA
My Car Makes A Loud Rough Squeak Right After The...
It Starts Right After It Turns Over And Makes The Noise For About 5 To 8 Seconds.
Asked by
importtuner
1995
NISSAN ALTIMA
VIEW MORE
SPONSORED LINKS
Battery Replacement Toyota
Battery Load Test
Battery Replacement Ford
Online car repair manuals
