1997 Nissan Altima
1997 NISSAN ALTIMA
MIKEU4PERU
Engine Performance problem
1997 Nissan Altima 4 cyl Two Wheel Drive Automatic
Our 1997 Nissan Altima, automatic, 4 cyl., 120k mi., starts hard. When idling it runs smoothly. When pressure applied to accelerator pedal, cuts out and dies unless several short jabs applied. Put in gear idles fine. When several jabs made to accelerator pedal and in low gear does not cut out. When put into higher gear, cuts out until RPMs are running higher. The only remedy attempted thus far is to add a water eliminating agent to the fuel. Thanks for your help, MU
Jul 3, 2008 at 3:45 AM
BMRFIXIT
  • 19,053 POSTS
check and change fuel filter
check fuel pressure
check it for tune up
Jul 6, 2008 at 2:24 PM
