1996 Nissan Altima Brake Pedal low
CARFOURLIFE
Brakes problem
1996 Nissan Altima 4 cyl Front Wheel Drive Automatic
The brake pedal on my car was very low, so I had to pump the pedal to be able to stop the car. So the master cylinder has been changed, bled before, the air in the brake lines has been removed, the pistons are good, the shoe line is good and the brakes and the pads have been replaced. The problem is that the pedal is still low and I have to pump to be able to stop the car. Is there another step to fix that problem? The brake fluid is fine. Nobody seems to be able to identify the problem and I can not drive the car in the condition.
Dec 8, 2008 at 11:20 AM
ZACKMAN
  • 4,202 POSTS
Have you tried adjusting the the pedal height? It should between 6.97 to 7.36 inches from the top of the pedal to the floor.
Dec 9, 2008 at 4:55 PM
