1996 Nissan Altima
168,741 MILES • 4 CYL • FWD • MANUAL
RAVI0701
when i am going on the free way my car's rpm suddenly goes down to zero and brakes and accelarator doesn't work brake gets tightened and accelarator becomesvery loose.upto now it happened 3 times.is there any major problem?
Nov 30, 2008 at 5:49 PM
  • 31,937 POSTS
HI there,
Thank you for the donation.
This is sounding as if you have an intermittent ignition fault, what you are describing could be the ignition cutting out and then coming back on again. What you will have to do first is get a scan and check for any set fault codes, also check that the ignition system loose ok, no loose wires things like that do this first and re post your findings.
mark (Mhpautos)
Nov 30, 2008 at 6:47 PM
