1995 Nissan Altima wierd problem.
KRAYZIE7TH
1995 Nissan Altima 4 cyl
Well i need some help, i am working on a 95 altime it was not getting fuel pressure and just replaced the fuel pump and it works now but now i have another issue.The car runs very rough at idle like its misfiring but as soon i disconnect the MAF it runs better. Could it be a faulty MAF?
Nov 18, 2008 at 7:39 AM
  • 31,937 POSTS
Hi there , do a scan first and check for any set fault codes, if you can get hold of a good known MAF to test on your car try that as well, there are tests that your mechanic can do on the sensor as well to prove its operation.
Mark (mhpautos)
Nov 18, 2008 at 7:45 AM
