1995 Nissan Altima stops running
DUSTY8531
  • 1995 NISSAN ALTIMA
Electrical problem
1995 Nissan Altima 4 cyl Front Wheel Drive Automatic 160. Miles
my car just quits running I replace the distributer cap and rotor and it runs just fine. But it happens all the time you will be driving down the road and it just quits running. What would cause this to happen help.
Thursday, January 14th, 2010 AT 6:34 PM
RACEME0911
  • 18 POSTS
Its actually a common this to my understanding with many different possible fixs. First start the car and wiggle the key to make sure its not a bad ignition cylinder. If its not that check your o ring under the distributor rotor button. If theres any oil at all replace the o ring. If that dont work check to see if u have exhaust pressure at tail pipe. If not its a clogged exhaust. Then go on to check your crank positioning sensor. Could also be bad wiring somewhere throughout the car. Good look if you narrow it down more ill have more answers
Friday, January 15th, 2010 AT 9:37 PM
