1995 Nissan Altima noisy belt
WEST3837
Other Category problem
1995 Nissan Altima 6 cyl 110000 miles
I HAVE A NOISY BELT I PURCHASED SOME BELT DRESSING SPRAYED IT ON THE GEN. BELT NOW THE NOISE IS LOUDER THEN BEFORE I DROVE THE CAR FOR ABOUT 1-MILE AFTER I SPRAYED DO U THINK IF I TOOK IT FOR A LONGER RUN THE NOISE MAY QUIET DOWN
Feb 5, 2008 at 6:09 AM
WEST3837
I SPRAYED SOME BELT DRESSING ON THE GEN. BELT NOW THE NOISE IS LOUDER THEN BEFORE
Feb 5, 2008 at 6:11 AM
2CARPRO JACK
  • 11,533 POSTS
There is a problem with the belt or an accessory that it is running.They squeek when too loose usually.Look closely at the belt for damage (cracking, glazing) if so then it needs to be replaced.Also look to see if any of the pulleys it runs on are crooked (not lined up straight), like a bearing has gone bad
Feb 5, 2008 at 11:47 PM
