1995 Nissan Altima fuel system
CASTROMANUEL21
Engine Mechanical problem
1995 Nissan Altima 4 cyl Front Wheel Drive Automatic
can a bad fuel pressure regulator keep my car from starting?
Jan 20, 2010 at 2:18 AM
RACEME0911
  • 18 POSTS
depends on the situation but quick answer yes. if it is not letting the proper pressure thru it will not let the injectors spray properly causing a misfire that will stop it from starting.
Jan 21, 2010 at 11:02 AM
