1995 Nissan Altima Engine clicking
137,000 MILES • 4 CYL • 2WD • AUTOMATIC
DILIPGHIMIRE
  • 10 POSTS
My nissan altima was sitting on my garage for atleast 5 months. I took it out a week ago and cleaned it up and now hear a clicking sound from the engine.
I have checked the oil level and its good.
Is is the rocker arm?
What is the solution and how much would it cost to repair?
Jul 29, 2010 at 9:56 AM
  • 75,988 POSTS
Do an engine flush oil galleries could be clogging up a bit with sludges and oil pressure no fully making it up there. If it continues you probably need to use shims for the clearance.
Jul 29, 2010 at 3:11 PM
DILIPGHIMIRE
  • 10 POSTS
So can I just buy an Engine Flush solvent from autozone and put it in the engine.
I will be changing my oil soon.
Do you recommend changing the oil first then adding the engine flush or add engine flush and then do a oil change.
Thanks
Jul 30, 2010 at 12:04 AM
  • 75,988 POSTS
add engine flush and then do a oil change. I use tranny fluid for a flush-1qt am poor cannot afford the good stuffs from NAPA
Jul 30, 2010 at 12:15 AM
