1995 Nissan Altima car dies and acts up.
1995 NISSAN ALTIMA
119,000 MILES • 4 CYL • FWD • MANUAL
REDDBOGUT
It isn't an everyday ordeal but when it the car warms up the lights will dim, the radio will start cutting out, and the tach will jump up and down, the engine will cut of and on but it hasn't died once I park it. If the lights are on it will run at less than 1,000 rpms, but if I turn the lights off it will jump to 2,000. Then when I turn it off it wont start like the battery is dead. If I let it sit overnight it will sometimes start, but mor often than naught the battery is dead. Once the battery is charged and the charging system is tested everything is normal. I have had the alternator checked and that is fine.
Feb 12, 2008 at 12:29 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it isnt charging when in the car. Have the charging system tested in the car and see what they come up with.
Feb 12, 2008 at 4:17 PM
