1995 Nissan Altima car dies
JESS33
Other Category problem
1995 Nissan Altima 4 cyl Wheel Drive Type unknown Automatic 18000 miles
just changed oil and oil filter and spark plugs. when i go to start car it will turn on. then when i want to take off it dies out. what could be the solution to this problem? does it have anything to do with catilstic converter?
Dec 31, 2007 at 9:13 AM
  • 75,988 POSTS
Was it doing that before you changed the oil and plugs? if not double check your work. Do a backpressure test on the exhaust system to rule out the catalytic converter pressure over 3psi is no good.
Dec 31, 2007 at 9:19 AM
