1995 Nissan Altima 1995 Nissan Altima Oil Pump
15,000 MILES • 4 CYL • FWD • AUTOMATIC
FIONAANNE
How To Replace Oil Pump For 1995 Nissan Altima? Or free online manual?
Jan 20, 2010 at 3:53 AM
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_oilp1_1.gif
https://images.2carpros.com/forum/automotive_pictures/12900_oilp2_1.jpg
REPLACEMENT 1. Remove front cover. Refer to Timing Chain. See: Timing Chain\Service and Repair 2. Remove oil pump cover. 3. Reverse procedure to install, noting the following: * Always replace oil seals and gaskets with new ones. * When installing oil pump, apply engine oil to inner and outer gears. * Use a scraper to remove old liquid gasket from mating surface of front cover and cylinder block.
Jan 20, 2010 at 8:11 AM
