1994 Nissan Altima water pump
ALTONBABY
  • 1994 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 225,000 MILES
How to check/replace water pump
Tuesday, October 14th, 2008 AT 8:12 AM
BMRFIXIT
  • 19,053 POSTS
WATER PUMP
Removal
Drain coolant from radiator and cylinder block.
Remove accessory drive belts. Remove water pump bolts and water pump.
Inspect water pump body and impeller vanes for corrosion. Check pump bearing for excessive play and rough operation..
Installation
Clean water pump and cylinder block mating surfaces. Apply a bead of sealant to water pump gasket surface.
Install water pump. Tighten water pump bolts to specification. Reverse removal procedure to complete installation. Fill cooling system. Pressure test cooling system. DO NOT apply more than 14 psi (1.0 kg/cm2 ) to system. .
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Tuesday, October 14th, 2008 AT 9:48 PM
