1994 Nissan Altima front bearing assembly
250,000 MILES • 6 CYL • FWD • AUTOMATIC
CBOXER57
Can I replace the bearing by removing the pads and rotor, or do I have to take the hub assembly off and have the bearing placed in by a shop?
Feb 2, 2008 at 12:44 AM
MERLIN2021
  • 17,250 POSTS
You will need to remove the knuckle from the car, then from the front side remove the snap ring, then put knuckle in a vice, and using the right size bearing driver, you can hammer it out...press is recommended to minimze shock to new bearing however!
Feb 2, 2008 at 12:53 AM
