1994 Nissan Altima
HURSTAUTOMOTIVE
  • 1994 NISSAN ALTIMA
Engine Mechanical problem
1994 Nissan Altima
car does not accelerate when you give it gas replaced maf sensor and distributor
Sunday, August 1st, 2010 AT 2:51 PM
If it's not slipping-see below:
Lack of acceleration, chugging, hesitating, bogging, misfiring etc. Could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sunday, August 1st, 2010 AT 9:00 PM
