air condition does not work not even does it throw or blow any air from the vents?
1993 NISSAN ALTIMA
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
PIANOMAN1871
I recently purchased a nissan altima it runs perfect only the air condition does not work not even does it throw or blow any air from the vents. Is it like discharged or is the blower motor gone bad relly I just wanna now why isint there even any air comining frome the vents please I need to know.?
Aug 6, 2009 at 3:36 AM
STEVEW84
  • 673 POSTS
So, you are saying that when you turn on the blower no air comes out of the vents?? If so, then you need to check if you are getting ground and power to the blower motor.
Aug 7, 2009 at 7:04 AM
AAP34798
  • 16 POSTS
the usual problem when ac air or heat doesn't flow from the vents even when turned on is a bad blower motor resistor. the pics are that of the 1995 altima but are typical of the flocks. naturally the resistor is located next to the blower motor, under the glove compartment, and held by 2 bolts. they are easy and cheap to replace and can be gotten cheapest by rockauto.com
https://images.2carpros.com/forum/automotive_pictures/400521_082509_19102_1.jpg
https://images.2carpros.com/forum/automotive_pictures/400521_082509_19141_3.jpg
https://images.2carpros.com/forum/automotive_pictures/400521_082509_19171_1.jpg
Aug 25, 2009 at 12:49 PM
