fuel injector change
165,085 MILES • 4 CYL • FWD • AUTOMATIC
TWEEEZZZY
when i change one do i need to change all of them to get the proper gas milage. I changed two of them and what is the easiest way to take them off without tire them up
Jul 10, 2008 at 4:17 AM
KHLOW2008
  • 41,812 POSTS
Hi tweeezzzy,
When you change 1, you don't need to change all, but it is preferable to do so or at least get those not changed serviced.
They are all plugged into the fuel rail so would all come off at the same time, only thing you can do is get them out sticking to the rails and not the cylinder head, then you won't affect the O rings.
May 25, 2021 at 6:30 AM
