1993 Nissan Altima code 34
260,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOE521
code 34 keep coming up replaced the knock senser ,and the ecm. runs great for about 20min and stills i will pay if someone help fix this problem thanks
Feb 4, 2009 at 8:38 AM
  • 75,988 POSTS
The knock sensor's job is when it senses engine vibration/detonation it will retard the ignition timing.
Stalling can be caused by anything that upsets the air/fuel mixture. This includes vacuum leaks or unmetered air entering the intake manifold downstream of the airflow sensor, a faulty throttle position, MAP or oxygen sensor, dirty fuel injectors, or low fuel pressure to the injectors (weak fuel pump, faulty fuel pressure regulator or restricted fuel filter
Feb 4, 2009 at 9:10 AM
