1993 Nissan Altima Brake Line.
1993 NISSAN ALTIMA
LAKAI326
Brakes problem
1993 Nissan Altima Automatic
A while ago my brakes went out and when I inspected the brakes, I noticed the brake line was leaking. I was just wondering how to fix or replace the brake lines and how much it would cost to replace them.
Oct 21, 2008 at 2:22 PM
ZACKMAN
  • 4,202 POSTS
Be ready to get brake fluid all over the garage.
Disconnect the rubber line from the metal line. Use flared wrench so you won't round off the nut. You can use a plier to take the clip off the strut assembly. Remove the brake line from the caliper with 12mm wrench. Install is reversed.
Then bleed your brake system.
Oct 22, 2008 at 2:21 PM
