1993 Nissan Altima
120,000 MILES • 4 CYL • FWD • AUTOMATIC
MUSHROOM MAN
hi had leaking from front axle seal drivers side replaced seal still leaks-replaced seal again still leaks puzzled?? if solved don't mind giving donation
Sep 7, 2009 at 3:13 PM
  • 31,937 POSTS
Hi there,
Is this leak from the seal lip or the seal in the housing, if from the seal lip check where the seal runs and make sure that there is no grove worn the original seal, make sure the seal feels firm on the shaft, check that the locating "C"clip is still on the end of the shaft and the shaft locks in when installed , check this next.
Mark (mhpautos)
Sep 7, 2009 at 7:05 PM
MUSHROOM MAN
hi-the leak is in where the axle goes into the seal in the middle it is like the seal is not tight enough against the axle. thanks
Sep 8, 2009 at 1:36 AM
  • 31,937 POSTS
Check for a grove where the seal lip is running and are you using a genuine seal?
Mark (mhpautos)
Sep 8, 2009 at 10:33 AM
MUSHROOM MAN
seal from nissan-leaks around axle shaft-axle locks in--is it possible problem with trans. it looks like axle is not sitting against seal tight enough. totally puzzled will try to send pix thanks
Sep 11, 2009 at 2:31 PM
  • 31,937 POSTS
If you can do that it will be a great help, hang in there we will get to the bottom of this problem.
mark.
Sep 11, 2009 at 2:57 PM
