HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Engine
Timing Belt
1989 Nissan Altima how to fix it
MD. MONIRUZZAMAN
MEMBER
1989 NISSAN ALTIMA
1989 Nissan Altima
How to fix the timing belt/ chain
Sunday, June 13th, 2010 AT 5:46 PM
MECHANIC
Put the engine no.1 piston on its compression stroke/TDC line all the markings on the sprockets as you see in the repair manual then put the chain or belt on-then adjust the ignition timing to specs.
Sunday, June 13th, 2010 AT 6:40 PM
Please
login
or
register
to post a reply.
Related Timing Belt Content
Engine Wiring I Need A Diagram
Where Can I Locate The Fuel Pump Relay For A 2006 Nissan Altima?
Asked by
YoungmasterE
21 IMAGES
2006
NISSAN ALTIMA
GUIDE
Timing Belt
Automotive combustion engines require either a timing chain or belt to keep the camshaft to crankshaft correlation correct as part of the design of the engine. A timing belt...
Mass Air Flow Error Code - Often Won't Start And Won't...
Right Now My Car Will Not Start, It Just Sounds Like Its Out Of Gas, It Trys To Turn Over But Doesn't. When It Does Manage To Start; I...
Asked by
eandj709
1 IMAGE
2005
NISSAN ALTIMA
Motor Mounts
Hello, I'm Having A Problem With My Car Listed Above, When I Switch From P To D Or From D To R It Does Like A Shaking Movement And...
Asked by
ofgarcia
7 IMAGES
2005
NISSAN ALTIMA
Vacuum Line Schematic/diagram
Where Can I Find A Vacuum Line Schematic/diagram? I Replaced My Motor But Some Of The Hoses Dry Rotted And Broke.
Asked by
j_k_melancon
3 IMAGES
1999
NISSAN ALTIMA
Air Control Valve - 2000 Nissan Altima
Hello I Put A New Air Control Valve And A New Pcm And The Car Is Still Running The Same. For Example The Rpms Are Still Going Up And Down Up...
Asked by
jvrepair
2000
NISSAN ALTIMA
VIEW MORE
Serpentine Belt Change Acura TL 2004-2008
Serpentine Belt Replacement Chevy 1500
Serpentine Belt Replacement Mercedes Benz
