Sometimes hard engine start
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
MKHAN786
i have hard time to start my car these days. most of time it start normal but some time its take so many cranks be start. i also got a indication service engine soon. i took to canadian tire they did the scan in my car its showing airflow sencer, Crank shaft sencer, engine speed sencer. they reset the computer to see i may get indication or not. i was driving in pavement road its working fine but as soon as i went on ruff road i got the indication service engine soon. plus some time it start giving me hard start. i really appricate if y can help me out here. i live in thompson.MB it really hard to get parts for nissan. i am thinking to change intake mass air flow sencer. and follow up slowly.
Nov 14, 2009 at 7:39 AM
DAVE H
  • 13,383 POSTS
start by replacing the mass airflow sensor and have the light turned off again .. see if any codes return !
Apr 25, 2010 at 10:23 PM
MARKUS0
My car has a hard time starting after sitting idle for 6 hours or so, (Cold climate)
I turn the key and it cranks for good 3 seconds before I stop, rest and crank again, it takes about 3-4 tries for the engine to turn over.
Once the engine has been running for a while I can start the car normally until it has been sitting for a while.
Car Idle is smooth, (RPM sits just below 1000 while in Park)
I took the car to a Nissan specialist and he connected the ground wire in the electrical system, and all that did was fix the speedometer and the RPM meter (which had stopped working)
I replaced spark plugs
I replaced starter
Battery charge was measured at around 50% at full charge (being replaced soon)
I took the car to the garage provided by the Nissan Dealership and they had it over night. They said that it was "maybe" the timing chain, and 1 out of 2 Oxygen Sensor was stuck at 0.29v and I was told it needed to be replaced.
They told me they needed to check the condition of the timing chain but I found that too expensive based on them saying it was "maybe" the cause of the problem.
They said nothing about the fuel system, I am not sure they even checked it.
The car runs smoothly, no backfires no misses, no loss in power.
light gasoline smell after having cranked for 3-4 seconds without results.
Doesn't seem anyone can diagnose my car without a bunch of "ifs and maybes"
Aug 20, 2019 at 8:13 AM (Merged)
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
you should start by checking your charging system due to the 50% charge of the battery. it shouldn't be that low unless the battery is going ba dor its not charging. since the car only has a hard time after sitting im suspect of the battery. charge it fully before checking it, as half charged batteries WILL fail a load test.
