2002 Nissan Almera THERMOSTAT
2002 NISSAN ALMERA
240,000 MILES • 4 CYL • FWD • MANUAL
SANJEEV1
COULD MY CAR RUN IF I REMOVE THE THERMOSTAT AS THE TEMPERAURE IN dURBAN, SOUTH AFRICA DOESNT GET TO COLD
Jun 5, 2009 at 1:24 AM
MIKE H R
  • 3,094 POSTS
the car will run , you might run into a problem, engines now a days need thermastats to slow down the circulations so the readiator has time to bring the coolant time to cool down enough. If it circulates too fast then the collant will not cool down. You can try it, in south africa I believe is a dryier heat.
Jun 5, 2009 at 2:27 AM
