2000 Nissan Almera car
92,000 MILES • 4 CYL • FWD • AUTOMATIC
DANIELLENICOL1
my nissan almera is chugging slighty in every gear what could be the problem? , i have already tried replacing the spark plugs.
Feb 25, 2010 at 10:08 AM
  • 75,988 POSTS
Hesitation,lack of acceleration,chugging,bogging:
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 25, 2010 at 10:15 AM
