2008 Nissan 350Z catalytic converter
2008 NISSAN 350Z
11,500 MILES • 6 CYL • 2WD • MANUAL
MGUERRA2008
I have a 2008 350z, code came up catalytic converter , they replaced it. Within one week the same code came on again? Does the car have more than one converter? what else should they look for? Thanks
Mike G
Dec 27, 2008 at 10:18 AM
  • 31,937 POSTS
Hi there there will be only one converter, if it has a down stream O2 sensor, ( behind the converter) this may be faulty, this is only used for calibration purposes and may be sending false information, otherwise get an exhaust gas test done and check for high hydrocarbon levels, this can be a leaking injector which can cause a converter to overheat, start here.
mark (mhpautos)
Dec 27, 2008 at 4:43 PM
