2004 Nissan 350Z Squelling Noise
REANIE
Noises problem
2004 Nissan 350Z Automatic 63,000 miles
When I start my car OR put it in reverse there is a SQUEELING noise. It doesn't happen every day but very often. I just had the main 2 belts replaced & a friend also put some belt dressing on it but it did not seem to help.
Nov 24, 2009 at 1:18 AM
ERNEST CLARK
  • 1,730 POSTS
You need to make sure you belts are tightened to spec. And don't put anymore "belt dressing" on it, unless you want to throw a belt off of your engine.
And if tightening your belts doesn't fix your problem, then check your alternator, a/c compressor, power steering pump and water pump and all of their pulleys. One/more may be the source of your noise.
Feb 23, 2010 at 9:37 AM
