1990 Nissan 300zx t/turbo Engine just died and won't start
CASUARINA
1990 Nissan 350Z
I was driving my to work and the engine just died when I stopped at the lights and it won't start again.
Apr 11, 2009 at 12:08 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Apr 11, 2009 at 12:11 AM
