1995 300ZX Will Not Start
GARY.WILSON
I have a 1995 300ZX that will not start. It is a 3.0 L V-6. 5 speed with 139,000 miles. The car has a new starter and battery, all fuses, fusable links, etc. are working, and the battery cables have been checked with a voltage meter.
I noticed that there is some type of silenoid by the clutch pedal. Is this something that could be causing my problem.
Oct 31, 2007 at 2:08 AM
BLACKOP555
  • 10,386 POSTS
will the car crank or no? if it wont crank check the saftey relay that tells the car the car is not engaged in gear by having the clutch pushed. also check for the blown fuses in the fuse box.
Oct 31, 2007 at 12:22 PM
