1994 Nissan 300ZX Door Locks Functioning on their own
1994 NISSAN 300ZX
60,000 MILES • V8 • 2WD • MANUAL
BREEZY1906
This morning I pulled into the parking lot, parked, & turned my car off. I unlocked my driver's side door from the inside. The locks began to flip back and forth from unlock to lock several times. In fact, I was lucky to get the door open. I put my key back in and started my car again. The locks again began to flip back and forth again. I have left the doors unlocked at this point for fear that I wont be able to get back into the car.
Any ideas on what might cause the locks to malfunction? Fuses, Battery in the key fob?
May 11, 2009 at 7:43 AM
BMRFIXIT
  • 19,053 POSTS
Lets start by checking fuses
check fuse # 15 and #4 its 10 a fuse #20 and # 9 in fuse block let kick panel
check fuse K and D in relay box fuse block left front shock tower under hood
check ground wire in center rear of trunk
check battery in fob
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 11, 2009 at 10:38 PM
