1992 Nissan 300ZX
1992 NISSAN 300ZX
SONUUBHI
Engine Performance problem
1992 Nissan 300ZX 6 cyl Two Wheel Drive Manual
Hi i've got 300zx twin turbo. car was fine two weeks ago but now when i drive it, its not going over 4000 rpm in every gear but in nutral its fine. turbo doesn't seem kicking. could you help me please
regards
Feb 20, 2010 at 3:46 PM
Z32BRYAN
  • 16 POSTS
[quote:a40af7a1b8="sonuubhi"]Engine Performance problem
regards[/quote:a40af7a1b8]
how many miles are on it? check the vacuum lines for cracking if you have vacuum leaks your not going to be boosting at where you want to be at (stock boost pressure is 9.5 psi)
the turbos should be replaced every 100,000 miles
Apr 9, 2010 at 7:01 AM
SONUUBHI
Hi mate
thanks for your reply
my car has got 84,000 miles on the clock
but car is not going over 4000 rpm in each gear. it seems like its in safe mode or restricted on 4000 rpm
but it was fine on 27/01/2010.
regards
Apr 30, 2010 at 9:47 AM
Z32BRYAN
  • 16 POSTS
check for a vacuum leak thats what im guessing is the problem
May 19, 2010 at 6:27 AM
