1991 nissan pick up
1991 NISSAN 300ZX
WRIPHI
I have A 91 nissan pick up 2.4 liter KA24E motor around one hundred thousand miles. I have put A new head on this motor. The motor idels fine but when you drive it above 3000 rpm it wants to stall and sputter like it is out of time. I have checked the timing and adjusted the timing but it will not run above 3000 rpm. Please advise me on where else to look.
Apr 22, 2007 at 10:02 AM
[quote:a22de3efc2="wriphi"]I have A 91 nissan pick up 2.4 liter KA24E motor around one hundred thousand miles. I have put A new head on this motor. The motor idels fine but when you drive it above 3000 rpm it wants to stall and sputter like it is out of time. I have checked the timing and adjusted the timing but it will not run above 3000 rpm. Please advise me on where else to look.[/quote:a22de3efc2]
Check the fuel presure and the throttle position sensor and airflow meter
Apr 22, 2007 at 12:33 PM
