hose is not connected - where can I find photo or diagram showing where it goes. Also, is replacing the washer motor a DIY job for novice?
May 2, 2009 at 1:10 PM
DAVE H
✓Experienced Mechanic
WASHER
NOTE:A check valve is located in washer line between reservoir tank and nozzle. If removed, install valve with arrow toward nozzle.
All models have windshield washer systems. A separate pump is used for the rear washer. On all models except Maxima, a common reservoir is used for both washer systems. Maxima models have a rear washer reservoir mounted in luggage compartment.
May 3, 2009 at 12:39 AM
