1990 Nissan 300ZX Crankshaft Pulley Bolt
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
ARMCER
  • 5 POSTS
How tight should the crankshaft pulley bolt go on?
Oct 6, 2010 at 1:54 PM
  • 75,988 POSTS
Torque it to 134-141 ft lbs
Oct 7, 2010 at 12:19 AM
ARMCER
  • 5 POSTS
I was only able to tighten the crank bolt to 90 ft. lbs. because the whole crankshaft would start turning. Is there a way to lock the crankshaft to keep it from spinning and be able to tighten the crank bolt to 134-141 ft. lbs.?
Oct 20, 2010 at 2:01 PM
  • 75,988 POSTS
By blocking the flexplate thru the inspection plate
Oct 20, 2010 at 5:24 PM
