1990 Nissan 300ZX
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAYDEAN175
i have a 1990 300zx, automatic tranmisson will not go into overdrive you can push the button on the stick on or off,overdrive light stays on
Feb 3, 2010 at 1:16 PM
KHLOW2008
  • 41,812 POSTS
Hi haydean175,
Thank you for the donation.
Does the OD Off light goes off when ignition is turned ON without the engine being started?
I suspect you have a faulty OD switch.
Feb 5, 2010 at 12:55 AM
