1988 Nissan 300ZX power window
1988 NISSAN 300ZX
170,000 MILES • 6 CYL • 2WD • MANUAL
DONNAMENARD
Drivers side window only works if I assist it. Window is able to lower very slowly sometimes, however, it seems to have an issue going up and that's when I need to push up with my hand while pressing the control button. Is it the motor or regulater or perhaps a more simple explanation?
Apr 11, 2009 at 9:22 AM
DEANWICKER
There is a rubber friction disk in the motor drive. As the disk ages it becomes less effective.
I modified mine by removing the rubber several years ago. Memory tells me I fabricated a disk from some large washers and bolted them in such a way it became a frictionless system.
So far no fingers got in the way when closing the window and nothing else failed because the friction disk was reconfigured.
Jul 31, 2009 at 10:08 PM
