Disconnect the coil connector and turn the ignition on, and check for power -the one with power is the positive side of the coil, the other is the negative side of the coil this is where you check for tach signal/switching of the primary circuit-
SPONSORED LINKS
Tuesday, February 10th, 2009 AT 5:45 PM
