My mechanic changed the timing belt and he mentioned that the old belt was advanced one tooth, now,the car runs strong but in order to do so I have to advance the timing through the distributor all the way to the right otherwise if I move it back just a bit it will run like crap and the problem is that both exhaust manifolds are getting red hot! Do I need to take the distributor out and move it one notch back!?
Thank you!
Ivan
Thank you!
Ivan
Mar 10, 2010 at 2:06 PM
